Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
Using tweezers, firmly grip the black lever at the bottom of the motherboard.
Use the tweezers to flip the black lever up so that it is upright from the motherboard.
Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
Carefully lift the capacitor away from the phone.
DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
Carefully tilt the motherboard up from the back of the phone.
Use tweezers to unclip the black connector.
Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
