はじめに
Use this guide to replace the ear speaker of the Samsung Mythic SGH-a897.
必要な工具と部品
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
Use the tweezers to unclip the connector.
Remove the daughterboard.
Use tweezers to unclip the silver connector.
Then put pressure on the black latch which is circled to release the speaker.
