はじめに
This guide will go over where to locate and replace the rear cooling fan if your fan no longer functions properly. You will need to reference the Removing Samsung ML2510 Back Panel repair guide to complete this one.
必要な工具と部品
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Once the fan is detached, unplug the fan from the circuit board.
Slide the fan's wiring through the anchored slit.
もう少しです!
ゴール
コメント 1 件
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
