はじめに
You will be required to disassemble much of the printer and its casing. You will need to refer to the Removing Samsung ML2510 Back Panel repair guide.
必要な工具と部品
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the cable attached to the motor.
The entire panel can be removed from the rest of the printer.
Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
Replace the motor and reassemble the printer by following the instructions in reverse order.
ある他の人がこのガイドを完成しました。
