必要な工具と部品
Remove fifteen Phillips screws securing the rear case to the front.
If present, remove four Phillips screws for the VESA mount.
Carefully lift the rear case upwards to separate it from the frame of the TV.
The Timing Controller (T-Con) board is located at the top center behind a metal shield.
Remove four Phillips screws.
Tilt the metal shield towards the top of the TV and lift away.
3 の人々がこのガイドを完成させました。
