メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Lay the TV screen-side down on a flat, soft surface.
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Remove fifteen Phillips screws securing the rear case to the front. If present, remove four Phillips screws for the VESA mount.
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
終わりに
3 の人々がこのガイドを完成させました。
Steven Carlton
メンバー登録日: 2013年08月19日
606 ポイント
3のガイドは作成済み
コメント1件
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 2,125
