Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Be careful, make sure you don't lose the screws.
Carefully squeeze the top right corner of the camera and pry off the external cover.
If you hear a "cracking" sound. This is normal.
Continue to pull the external cover and it will come off cleanly.
Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
Remove the screws holding the circuit board.
After you remove the screws, carefully remove the circuit board.
Carefully hold up the circuit board, while it's still connected to the camera.
Remove all five screws that's on top of the camera.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
