この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the speaker.
必要な工具と部品
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
ある他の人がこのガイドを完成しました。
