The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
Insert the Plastic Opening Tool in between the front and rear cases.
Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
Use a spudger to disconnect the Motherboard ribbon cable.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
