この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to install a new speaker.
必要な工具と部品
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
もう少しです!
終わりに
