メインコンテンツにスキップ
Samsung Instinct Front Case Replacement
必要な工具と部品
  1. Samsung Instinct Front Case Replacement, Battery: 手順 1、 1の画像 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Front Case Replacement: 手順 2、 1の画像 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Front Case Replacement, Back Case: 手順 3、 1の画像 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Front Case Replacement: 手順 4、 2の画像 1 Samsung Instinct Front Case Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Front Case Replacement: 手順 5、 1の画像 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Front Case Replacement, Antenna: 手順 6、 1の画像 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Front Case Replacement: 手順 7、 1の画像 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Front Case Replacement: 手順 8、 1の画像 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Front Case Replacement: 手順 9、 1の画像 1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Front Case Replacement, Front Case: 手順 10、 1の画像 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Front Case Replacement: 手順 11、 3の画像 1 Samsung Instinct Front Case Replacement: 手順 11、 3の画像 2 Samsung Instinct Front Case Replacement: 手順 11、 3の画像 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Front Case Replacement: 手順 12、 1の画像 1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Front Case Replacement: 手順 13、 2の画像 1 Samsung Instinct Front Case Replacement: 手順 13、 2の画像 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Front Case Replacement: 手順 14、 1の画像 1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Front Case Replacement: 手順 15、 1の画像 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
終わりに
作成者
6人の作成者と共同で作成されました。
Jacob Michener
メンバー登録日: 10/10/11
31 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G13
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 718
