はじめに
How to remove & replace the phone's LCD screen.
必要な工具と部品
Orient the phone with the screen facing downward.
Slide the panel away from the camera using your thumb. This will expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
Gently remove the black wire to free the circuit board.
Remove the wire by gently prying up the gold terminator attached to the green circuit board.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove the 3 screws holding down the flex cable.
The two screws on the black frame are 2.0 mm in length.
The top right screw that goes through the circle port on the flex cable is 2.3 mm.
Remove the keyboard slider frame. The flex cable should be exposed, but not free.
Remove the 2.25 mm screw.
Lift the black tab at the end of the ribbon.
Gently pull the speaker and ribbon free.
