メインコンテンツにスキップ
Samsung Impression Ear Speaker Replacement
必要な工具と部品
  1. Samsung Impression Ear Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Ear Speaker Replacement: 手順 2、 2の画像 1 Samsung Impression Ear Speaker Replacement: 手順 2、 2の画像 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Ear Speaker Replacement, Back Cover: 手順 3、 1の画像 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Ear Speaker Replacement: 手順 4、 1の画像 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Ear Speaker Replacement, Circuit Board: 手順 5、 1の画像 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Ear Speaker Replacement: 手順 6、 2の画像 1 Samsung Impression Ear Speaker Replacement: 手順 6、 2の画像 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Ear Speaker Replacement, Keyboard: 手順 7、 1の画像 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
  8. Samsung Impression Ear Speaker Replacement: 手順 8、 2の画像 1 Samsung Impression Ear Speaker Replacement: 手順 8、 2の画像 2
    • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
    • The keys will peel right out of the screen side of the phone.
  9. Samsung Impression Ear Speaker Replacement: 手順 9、 1の画像 1
    • The silver piece you are left with is the physical keyboard assembly.
  10. Samsung Impression Ear Speaker Replacement, LCD Flex Cable: 手順 10、 2の画像 1 Samsung Impression Ear Speaker Replacement, LCD Flex Cable: 手順 10、 2の画像 2
    • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
    • The keyboard slider frame will come off and the flex cable exposed, but not free.
  11. Samsung Impression Ear Speaker Replacement: 手順 11、 1の画像 1
    • Remove 4 outer screws.
    • The screws are 3.5mm in length.
  12. Samsung Impression Ear Speaker Replacement: 手順 12、 3の画像 1 Samsung Impression Ear Speaker Replacement: 手順 12、 3の画像 2 Samsung Impression Ear Speaker Replacement: 手順 12、 3の画像 3
    • Slide the phone apart, and remove a 5th screw (3.5 mm).
    • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
    • The device will now be in two pieces
  13. Samsung Impression Ear Speaker Replacement: 手順 13、 2の画像 1 Samsung Impression Ear Speaker Replacement: 手順 13、 2の画像 2
    • Lift the tab underneath the blue tape and gently pull the flex cable.
    • The flex cable will now be completely free.
  14. Samsung Impression Ear Speaker Replacement, Ear Speaker: 手順 14、 1の画像 1
    • Remove the single screw.
    • This screw is 2.25 mm in length.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
終わりに
作成者
5人の作成者と共同で作成されました。
Saul Villatoro
メンバー登録日: 04/25/11
255 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G10
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 3,253
