この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
How to remove & replace the phone's digitizer or front buttons
必要な工具と部品
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove the 3 screws holding down the flex cable.
The screws are 2.0 mm in length.
The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
The keyboard slider frame will come off and the flex cable exposed, but not free.
Remove the single screw.
This screw is 2.25 mm in length.
Lift the black tab at the end of the ribbon.
Gently pull the speaker and ribbon free.
If replacing the front buttons, remove the assembly at the bottom of the front panel
The digitizer is now free to be pulled out from the front housing.
3 の人々がこのガイドを完成させました。
