メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Impression Digitizer or Front Buttons Replacement
必要な工具と部品
  1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: 手順 1、 1の画像 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Impression Digitizer or Front Buttons Replacement: 手順 2、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement: 手順 2、 2の画像 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: 手順 3、 1の画像 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Impression Digitizer or Front Buttons Replacement: 手順 4、 1の画像 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: 手順 5、 1の画像 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Impression Digitizer or Front Buttons Replacement: 手順 6、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement: 手順 6、 2の画像 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: 手順 7、 1の画像 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Impression Digitizer or Front Buttons Replacement: 手順 8、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement: 手順 8、 2の画像 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Impression Digitizer or Front Buttons Replacement: 手順 9、 1の画像 1
    • The silver piece you are left with is the physical keyboard assembly.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: 手順 10、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: 手順 10、 2の画像 2
    • Remove the 3 screws holding down the flex cable.
    • The two screws on the black frame are 2.0 mm in length.
    • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
    • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Impression Digitizer or Front Buttons Replacement: 手順 11、 1の画像 1
    • Remove the four 3.5 mm outer screws.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Impression Digitizer or Front Buttons Replacement: 手順 12、 3の画像 1 Samsung Impression Digitizer or Front Buttons Replacement: 手順 12、 3の画像 2 Samsung Impression Digitizer or Front Buttons Replacement: 手順 12、 3の画像 3
    • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
    • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
    • The device will now be in two pieces (fig. 3).
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Impression Digitizer or Front Buttons Replacement: 手順 13、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement: 手順 13、 2の画像 2
    • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
    • The flex cable will now be completely free (fig. 2).
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: 手順 14、 1の画像 1
    • Remove the 2.3 mm screw.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Impression Digitizer or Front Buttons Replacement, LCD: 手順 15、 2の画像 1 Samsung Impression Digitizer or Front Buttons Replacement, LCD: 手順 15、 2の画像 2
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
    FixBotに聞いてみる
    コメントを追加
  16. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: 手順 16、 1の画像 1
    • If replacing the front buttons, remove the assembly at the bottom of the front panel
    • The digitizer is now free to be pulled out from the front housing.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Saul Villatoro
メンバー登録日: 04/25/11
260 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G10
4 メンバー
45のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 35
今までの合計 7,247
