はじめに
How to remove & replace the phone's back speaker.
必要な工具と部品
Orient the phone with the screen facing downward.
Slide the panel away from the camera using your thumb. This will expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
Carefully pry the back speaker upwards with a spudger.
Disconnect the speaker by lifting the clear plastic piece attached to the wire.
終わりに
3 の人々がこのガイドを完成させました。
