この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
How to remove & replace the phone's antenna.
必要な工具と部品
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
ある他の人がこのガイドを完成しました。
