メインコンテンツにスキップ
Samsung Impression Antenna Replacement
必要な工具と部品
  1. Samsung Impression Antenna Replacement, Battery: 手順 1、 1の画像 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Antenna Replacement: 手順 2、 2の画像 1 Samsung Impression Antenna Replacement: 手順 2、 2の画像 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Antenna Replacement, Back Cover: 手順 3、 1の画像 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Antenna Replacement: 手順 4、 1の画像 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Antenna Replacement, Circuit Board: 手順 5、 1の画像 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Antenna Replacement: 手順 6、 2の画像 1 Samsung Impression Antenna Replacement: 手順 6、 2の画像 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Antenna Replacement, Antenna: 手順 7、 2の画像 1 Samsung Impression Antenna Replacement, Antenna: 手順 7、 2の画像 2
    • Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
    • The antenna assembly will snap off.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Saul Villatoro
メンバー登録日: 04/25/11
255 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G10
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,885
