メインコンテンツにスキップ
はじめに
Demonstrates how to replace the rear case of the camera through instructive pictures and words. Replacement of rear case requires the removal of the motherboard and LCD screen.
  1. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
    • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  2. Remove all four Hex screws with a Hex 1.5 mm screwdriver. Remove all four Hex screws with a Hex 1.5 mm screwdriver.
    • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  3. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
    • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  4. As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
    • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
    • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  5. Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers.
    • Pull the wire ribbon out with a pair of tweezers.
  6. Use tweezers to remove the tape. Use tweezers to remove the tape. Use tweezers to remove the tape.
    • Use tweezers to remove the tape.
  7. Use tweezers to grab the wire ribbon, then pull the wire out of connection. Use tweezers to grab the wire ribbon, then pull the wire out of connection.
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. There are 5 Phillips size 00 screws. Remove all 5 screws. Wire ribbon is attached to the motherboard.
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Pry the motherboard up using the  plastic opening tool.
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case. Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Use Phillips size 00 and remove the 3 screws as shown. Use Phillips size 00 and remove the 3 screws as shown. Use Phillips size 00 and remove the 3 screws as shown.
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Pry the end of the screen with the plastic opening tool. Pry the end of the screen with the plastic opening tool.
    • Pry the end of the screen with the plastic opening tool.
  13. Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case. Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case. Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
  14. Removal of the rear case is completed.
    • Removal of the rear case is completed.
終わりに
Robert
メンバー登録日: 2015年01月21日
966 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S9G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 217
