はじめに
Demonstrates how to replace the rear case of the camera through instructive pictures and words. Replacement of rear case requires the removal of the motherboard and LCD screen.
パーツ
パーツは指定されていません。
To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
