この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Shows how to replace motherboard with pictures and words. Removal of motherboard requires opening the camera and unscrewing screws from motherboard to remove from rear case.
必要な工具と部品
To remove the wristband of the device, grab the middle loop and pull the band through.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
ある他の人がこのガイドを完成しました。
