はじめに
The battery is located inside the camera. It will require uninstalling the battery housing, illustrated in the guide below.
必要な工具と部品
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
