はじめに
When the outer lens of an HMX-F90 Camcorder is scratched or scuffed it can require replacement. This guide will show you how to remove the outer lens
必要な工具と部品
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
終わりに
3 の人々がこのガイドを完成させました。
