メインコンテンツにスキップ
Samsung Gravity TXT Motherboard Replacement
必要な工具と部品
  1. Samsung Gravity TXT Motherboard Replacement, Battery: 手順 1、 2の画像 1 Samsung Gravity TXT Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT Motherboard Replacement: 手順 2、 1の画像 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT Motherboard Replacement: 手順 3、 1の画像 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT Motherboard Replacement, SIM Card: 手順 4、 3の画像 1 Samsung Gravity TXT Motherboard Replacement, SIM Card: 手順 4、 3の画像 2 Samsung Gravity TXT Motherboard Replacement, SIM Card: 手順 4、 3の画像 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
  5. Samsung Gravity TXT Motherboard Replacement, microSD Card: 手順 5、 3の画像 1 Samsung Gravity TXT Motherboard Replacement, microSD Card: 手順 5、 3の画像 2 Samsung Gravity TXT Motherboard Replacement, microSD Card: 手順 5、 3の画像 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
  6. Samsung Gravity TXT Motherboard Replacement, Plastic Back Frame: 手順 6、 1の画像 1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
  7. Samsung Gravity TXT Motherboard Replacement: 手順 7、 3の画像 1 Samsung Gravity TXT Motherboard Replacement: 手順 7、 3の画像 2 Samsung Gravity TXT Motherboard Replacement: 手順 7、 3の画像 3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
  8. Samsung Gravity TXT Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
  9. Samsung Gravity TXT Motherboard Replacement: 手順 9、 3の画像 1 Samsung Gravity TXT Motherboard Replacement: 手順 9、 3の画像 2 Samsung Gravity TXT Motherboard Replacement: 手順 9、 3の画像 3
    • Use your finger nail to disconnect the display data cable from the motherboard.
  10. Samsung Gravity TXT Motherboard Replacement: 手順 10、 2の画像 1 Samsung Gravity TXT Motherboard Replacement: 手順 10、 2の画像 2
    • Carefully lift the main motherboard assembly away from the front panel.
終わりに
作成者
3人の作成者と共同で作成されました。
Mounir Karmada
メンバー登録日: 07/07/15
465 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015人のメンバー
IUPUI-RENGUETTE-SU15S1G1
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 371
