はじめに
This guide will provide a step by step procedure for installing the internal antenna.
  1. Using your thumb, press down and slide the back cover away from the  camera.
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  5. Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap. Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  6. The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends. Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  7. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
まとめ
Cameron Law
メンバー登録日: 2011年10月12日
142 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G12
4 メンバー
14のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 983
