メインコンテンツにスキップ
Samsung Gear VR with Controller Inner Mask Replacement
必要な工具と部品
  1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 手順 1、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 手順 1、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 手順 1、 3の画像 3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR with Controller Inner Mask Replacement: 手順 2、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 2、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement: 手順 2、 3の画像 3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR with Controller Inner Mask Replacement: 手順 3、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 3、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement: 手順 3、 3の画像 3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR with Controller Inner Mask Replacement: 手順 4、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 4、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement: 手順 4、 3の画像 3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR with Controller Inner Mask Replacement: 手順 5、 2の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 5、 2の画像 2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR with Controller Inner Mask Replacement: 手順 6、 2の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 6、 2の画像 2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR with Controller Inner Mask Replacement: 手順 7、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 7、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement: 手順 7、 3の画像 3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR with Controller Inner Mask Replacement: 手順 8、 3の画像 1 Samsung Gear VR with Controller Inner Mask Replacement: 手順 8、 3の画像 2 Samsung Gear VR with Controller Inner Mask Replacement: 手順 8、 3の画像 3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Harumi Hokari
メンバー登録日: 01/24/19
243 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 287
