はじめに
If the lenses on your Samsung Gear VR with Controller are blurry, scratched, or damaged, use this guide to replace one or both of your lenses. For this guide, you will need a plastic opening tool, metal spudger, and Phillips #000 screwdriver head.
必要な工具と部品
Push the switch on the right-hand side of the device to separate the cover from the main body.
Pull the cover away from the main device.
ある他の人がこのガイドを完成しました。
