メインコンテンツにスキップ
Samsung Gear VR Motherboard Replacement
必要な工具と部品
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 手順 1、 3の画像 1 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 手順 1、 3の画像 2 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 手順 1、 3の画像 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: 手順 2、 2の画像 1 Samsung Gear VR  Motherboard Replacement: 手順 2、 2の画像 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: 手順 3、 1の画像 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: 手順 4、 1の画像 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
終わりに
作成者
5人の作成者と共同で作成されました。
David Forlano
メンバー登録日: 09/25/17
119 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G6
4 メンバー
7のガイドは作成済み
コメント 1 件
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 1,551
