メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your device's touchscreen is unresponsive or cracked, replace it with this guide. This will require you to replace the whole front screen assembly, as you can't just replace the screen itself.
パーツ
パーツは指定されていません。
  1. Place the watch screen-down so that its back cover is showing.
    • Place the watch screen-down so that its back cover is showing.
  2. Remove the four 4.2mm screws with a Y00 screwdriver. Remove the four 4.2mm screws with a Y00 screwdriver.
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  4. Wedge the metal spudger in between the back cover and the frame along the seam. Use force to pry the back cover away from the main watch frame. This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
    • This step will ruin the water-proof seal.
  5. Detach the three connectors on the motherboard using your fingernail. The connectors are easy to pop off. Minimal force is necessary. The connectors are easy to pop off. Minimal force is necessary.
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  6. Separate the motherboard and front screen assembly using a spudger. Separate the motherboard and front screen assembly using a spudger. Separate the motherboard and front screen assembly using a spudger.
    • Separate the motherboard and front screen assembly using a spudger.
    Oui tuto bien clair. Opération réussi !
    Bien qu’adroit de mes mains, et après avoir découvert la “bête à coeur ouvert”, je ne sais pas si je me serais lancé... C’est tout l’interêt de ce Tuto qui invite à le faire (car pas trop de détails), et qui suivit pas à pas permet de s’en sortir. Bravo
    Merci Dan.S
    Dan.S - 返信
    Ustedes reparan el gear s3 Frontier? El mío presenta una falla, algunas veces se ve la pantalla, otras veces solo muestra un error y se pone oscura, no sé si sea la placa o la pantalla la que de el error. Gracias
    Daniel Albornoz - 返信
    Better replace the 2 bolts from next step first.
    Gabriel Pinho - 返信
終わりに
10 の人々がこのガイドを完成させました。
Jimmy Algeo
メンバー登録日: 2018年10月08日
601 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G2
4 メンバー
33のガイドは作成済み
5 件のコメント
can you tell me where can i buy the whole front screen  ?
Ahmad Hariki - 返信
Jerzy Jerzyk - 返信
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
ArcadeDude44 - 返信
Can anyone please tell, where to get the parts?
Sunny Tate - 返信
Eleazar Lagundino - 返信
コメントを追加
統計データを表示:
過去 24時間: 13
過去 7 日: 68
過去 30 日: 309
今までの合計 10,725
