メインコンテンツにスキップ
Samsung Gear S2 Battery Replacement
必要な工具と部品
  1. Samsung Gear S2 Battery Replacement, Watch Strap: 手順 1、 2の画像 1 Samsung Gear S2 Battery Replacement, Watch Strap: 手順 1、 2の画像 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Battery Replacement: 手順 2、 2の画像 1 Samsung Gear S2 Battery Replacement: 手順 2、 2の画像 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Battery Replacement: 手順 3、 2の画像 1 Samsung Gear S2 Battery Replacement: 手順 3、 2の画像 2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Battery Replacement, Back: 手順 4、 2の画像 1 Samsung Gear S2 Battery Replacement, Back: 手順 4、 2の画像 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Battery Replacement, Motherboard: 手順 5、 2の画像 1 Samsung Gear S2 Battery Replacement, Motherboard: 手順 5、 2の画像 2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Battery Replacement: 手順 6、 3の画像 1 Samsung Gear S2 Battery Replacement: 手順 6、 3の画像 2 Samsung Gear S2 Battery Replacement: 手順 6、 3の画像 3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Battery Replacement: 手順 7、 2の画像 1 Samsung Gear S2 Battery Replacement: 手順 7、 2の画像 2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
  8. Samsung Gear S2 Battery Replacement, Battery: 手順 8、 2の画像 1 Samsung Gear S2 Battery Replacement, Battery: 手順 8、 2の画像 2
    • Using tweezers, lift the battery casing.
    • Make sure the cables are fed through their gaps to avoid damaging them.
  9. Samsung Gear S2 Battery Replacement: 手順 9、 2の画像 1 Samsung Gear S2 Battery Replacement: 手順 9、 2の画像 2
    • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
    • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
終わりに
100 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jacob Baldwin
メンバー登録日: 02/20/17
3,412 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S2G3
3 メンバー
23のガイドは作成済み
39 件のコメント
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - 返信
A reference to the battery part number would be great.
Harold Turner - 返信
Very good job and very easy
JEAN PIERRE - 返信
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - 返信
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 114
過去 30 日: 515
今までの合計 153,187
