メインコンテンツにスキップ
Samsung Gear S2 3G Battery Replacement
必要な工具と部品
  1. Samsung Gear S2 3G Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the four screws that surround the back housing of the device.
    • Removing the back housing requires a Y00 tri-wing screw head.
  2. Samsung Gear S2 3G Battery Replacement: 手順 2、 1の画像 1
    • Remove one J00 phillips-head screw from the mainboard, freeing the board from the frame. The board still has 5 connectors and adhesive, do not begin the removal of the board.
  3. Samsung Gear S2 3G Battery Replacement: 手順 3、 1の画像 1
    • Remove five snap-in flex connectors from around the edges of the mainboard.
  4. Samsung Gear S2 3G Battery Replacement: 手順 4、 1の画像 1
    • Easily pry the mainboard from the frame, being careful not to rip the vibrate motor flex on the top of the mainboard, it is curled around the top.
    • The vibrate motor is not secured by any adhesive, it should lift from it's housing without ripping the flex, but be careful.
  5. Samsung Gear S2 3G Battery Replacement: 手順 5、 2の画像 1 Samsung Gear S2 3G Battery Replacement: 手順 5、 2の画像 2
    • After removing the mainboard, the battery should be in full display.
    • Easily pry the battery from the right hand side, careful not to insert the prytool too far, the device's LCD is directly underneath the battery.
    • Seat in the new battery, if it doesn't fit perfectly, do not bend, pinch or puncture the battery to make it fit, some corners may need to be pressed in, be careful.
    • Reseat the battery connector, using adhesive if the part does not have it behind the connector.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Edwin Roberts
メンバー登録日: 06/04/17
233 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 2,339
