メインコンテンツにスキップ
Samsung Gear Live Vibrator Motor Replacement
必要な工具と部品
  1. Samsung Gear Live Vibrator Motor Replacement, Lay the watch face-down: 手順 1、 1の画像 1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Vibrator Motor Replacement, Remove the holding pin: 手順 2、 1の画像 1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Vibrator Motor Replacement, Remove the watchband: 手順 3、 1の画像 1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Vibrator Motor Replacement, Locate the four screws: 手順 4、 1の画像 1
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Vibrator Motor Replacement, Remove the 4 screws: 手順 5、 1の画像 1
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Vibrator Motor Replacement, Pry off the back of the watch.: 手順 6、 1の画像 1
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Vibrator Motor Replacement, Lift off the back cover: 手順 7、 2の画像 1 Samsung Gear Live Vibrator Motor Replacement, Lift off the back cover: 手順 7、 2の画像 2
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Vibrator Motor Replacement, Set both halves of the watch aside: 手順 8、 1の画像 1
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Vibrator Motor Replacement, Locate the vibrator motor: 手順 9、 1の画像 1
    • Locate the vibrator motor on the front half of the disassembled watch. It is located in the corner, at the end opposite the green circuit board.
  10. Samsung Gear Live Vibrator Motor Replacement, Pry up the motor: 手順 10、 1の画像 1
    • Using the plastic opening tool, gently pry up the motor.
  11. Samsung Gear Live Vibrator Motor Replacement, Pry up the motor contacts: 手順 11、 1の画像 1
    • Using the plastic prying tool, gently pry away the motor’s contacts and ribbon cable from the watch assembly
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Keith Cooper
メンバー登録日: 09/25/14
1,241 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G7
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 1,329
