メインコンテンツにスキップ
Samsung Gear Live Battery Replacement
必要な工具と部品
  1. Samsung Gear Live Battery Replacement, Lay the watch face-down: 手順 1、 1の画像 1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Battery Replacement, Remove the holding pin: 手順 2、 1の画像 1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Battery Replacement, Remove the watchband: 手順 3、 1の画像 1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Battery Replacement, Locate the four screws: 手順 4、 1の画像 1
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Battery Replacement, Remove the 4 screws: 手順 5、 1の画像 1
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Battery Replacement, Pry off the back of the watch.: 手順 6、 1の画像 1
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Battery Replacement, Lift off the back cover: 手順 7、 2の画像 1 Samsung Gear Live Battery Replacement, Lift off the back cover: 手順 7、 2の画像 2
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Battery Replacement, Set both halves of the watch aside: 手順 8、 1の画像 1
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Battery Replacement, Locate the battery: 手順 9、 1の画像 1
    • Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
  10. Samsung Gear Live Battery Replacement, Locate the battery contacts: 手順 10、 1の画像 1
    • Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
    • Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
  11. Samsung Gear Live Battery Replacement, Pry out the battery: 手順 11、 1の画像 1
    • Gently work the plastic opening tool under the battery.
    • Using the plastic opening tool, gently pry the battery up.
    • If replacing the battery, please dispose of it properly. Do not throw the battery in the trash. Contact your local municipality for locations which accept lithium-ion batteries for disposal or recycling.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Keith Cooper
メンバー登録日: 09/25/14
1,241 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G7
3 メンバー
6のガイドは作成済み
7 件のコメント
Indicate the tools needed.
Dan Brown - 返信
Indicate screw measurements to nearest mm.
Dan Brown - 返信
This is neat and helpful, but where do I find a replacement battery?
joshthehappy - 返信
Where can I purchase these batteries?
chad flores - 返信
I purchased my battery on eBay.
Jay -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 9,446
