メインコンテンツにスキップ
Samsung Gear 2 Neo Display Replacement
必要な工具と部品
  1. Samsung Gear 2 Neo Display Replacement, Battery: 手順 1、 1の画像 1
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Display Replacement: 手順 2、 2の画像 1 Samsung Gear 2 Neo Display Replacement: 手順 2、 2の画像 2
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Display Replacement: 手順 3、 1の画像 1
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Display Replacement: 手順 4、 2の画像 1 Samsung Gear 2 Neo Display Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Samsung Gear 2 Neo Display Replacement, Motherboard: 手順 5、 1の画像 1
    • Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
  6. Samsung Gear 2 Neo Display Replacement: 手順 6、 1の画像 1
    • It is recommended to use antistatic wrist wrap whenever removing the motherboard.
    • Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
    • Attached to the motherboard is the infrared LED Light. To replace the IR LED, you may need to replace the entire motherboard.
  7. Samsung Gear 2 Neo Display Replacement, Display: 手順 7、 1の画像 1
    • Use the spudger and apply pressure to the back of the AMOLED display.
    • Make sure to stay within the area marked to avoid damaging the device.
  8. Samsung Gear 2 Neo Display Replacement: 手順 8、 1の画像 1
    • Once part of the display begins detaching from the front cover, place the spduger in between the display and the front cover.
  9. Samsung Gear 2 Neo Display Replacement: 手順 9、 1の画像 1
    • Use the spudger to scrape off the adhesive located on the bottom side of the display, attaching the display to the front cover.
    • Be careful when doing this step as it could potentially break the display and/or the case if not followed properly.
  10. Samsung Gear 2 Neo Display Replacement: 手順 10、 1の画像 1
    • After the adhesive has been removed, apply pressure with the spudger to the back of the AMOLED display; the display should pop right out.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Victor Yore
メンバー登録日: 08/27/15
705 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 5-6, Blackwell Fall 2015 USF Tampa, Team 5-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S5G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 6,100
