メインコンテンツにスキップ
Samsung Galaxy Y Charging port and headphone jack Replacement
必要な工具と部品
  1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 手順 1、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 手順 1、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 手順 1、 3の画像 3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 手順 2、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 手順 2、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 手順 2、 3の画像 3
    • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 3、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 3、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 3、 3の画像 3
    • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 4、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 4、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 4、 3の画像 3
    • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
  5. Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 5、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 5、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 5、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
  6. Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 6、 3の画像 1 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 6、 3の画像 2 Samsung Galaxy Y Charging port and headphone jack Replacement: 手順 6、 3の画像 3
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alyissa
メンバー登録日: 09/21/18
133 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S5-G4, Thompson Fall 2018 University of North Texas, Team S5-G4, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 613
