メインコンテンツにスキップ
Samsung Galaxy Xcover GT-S5690 LCD Replacement
必要な工具と部品
  1. Samsung Galaxy Xcover GT-S5690 LCD Replacement, LCD: 手順 1、 1の画像 1
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
  2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 2、 1の画像 1
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
  3. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 3、 2の画像 1 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 3、 2の画像 2
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
  4. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 4、 2の画像 1 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 4、 2の画像 2
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
  5. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 5、 3の画像 1 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 5、 3の画像 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 5、 3の画像 3
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
  6. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 6、 2の画像 1 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 6、 2の画像 2
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
  7. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 7、 2の画像 1 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 手順 7、 2の画像 2
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jaime
メンバー登録日: 11/05/13
3,333 ポイント
4のガイドは作成済み
コメント 1 件
Good and clear. Pics are much better than movie, thank you very much!
pierrequivoyage - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 6,819
