メインコンテンツにスキップ
Samsung Galaxy View Speakers Replacement
必要な工具と部品
  1. Samsung Galaxy View Speakers Replacement, Kickstand: 手順 1、 1の画像 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Speakers Replacement: 手順 2、 3の画像 1 Samsung Galaxy View Speakers Replacement: 手順 2、 3の画像 2 Samsung Galaxy View Speakers Replacement: 手順 2、 3の画像 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Speakers Replacement, Battery: 手順 3、 2の画像 1 Samsung Galaxy View Speakers Replacement, Battery: 手順 3、 2の画像 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Speakers Replacement: 手順 4、 3の画像 1 Samsung Galaxy View Speakers Replacement: 手順 4、 3の画像 2 Samsung Galaxy View Speakers Replacement: 手順 4、 3の画像 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Speakers Replacement: 手順 5、 3の画像 1 Samsung Galaxy View Speakers Replacement: 手順 5、 3の画像 2 Samsung Galaxy View Speakers Replacement: 手順 5、 3の画像 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Speakers Replacement: 手順 6、 2の画像 1 Samsung Galaxy View Speakers Replacement: 手順 6、 2の画像 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Speakers Replacement: 手順 7、 3の画像 1 Samsung Galaxy View Speakers Replacement: 手順 7、 3の画像 2 Samsung Galaxy View Speakers Replacement: 手順 7、 3の画像 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Speakers Replacement, Speakers: 手順 8、 3の画像 1 Samsung Galaxy View Speakers Replacement, Speakers: 手順 8、 3の画像 2 Samsung Galaxy View Speakers Replacement, Speakers: 手順 8、 3の画像 3
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Speakers Replacement: 手順 9、 2の画像 1 Samsung Galaxy View Speakers Replacement: 手順 9、 2の画像 2
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
終わりに
作成者
3人の作成者と共同で作成されました。
Miguel Becerra
メンバー登録日: 10/06/16
251 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,073
