メインコンテンツにスキップ
Samsung Galaxy View Sound and Power Buttons Replacement
必要な工具と部品
  1. Samsung Galaxy View Sound and Power Buttons Replacement, Kickstand: 手順 1、 1の画像 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 2、 3の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 2、 3の画像 2 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 2、 3の画像 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Sound and Power Buttons Replacement, Battery: 手順 3、 2の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement, Battery: 手順 3、 2の画像 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 4、 3の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 4、 3の画像 2 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 4、 3の画像 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 5、 3の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 5、 3の画像 2 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 5、 3の画像 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 6、 2の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 6、 2の画像 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 7、 3の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 7、 3の画像 2 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 7、 3の画像 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Sound and Power Buttons Replacement, Sound and Power Buttons: 手順 8、 1の画像 1
    • Use your fingers to pull the blue no-fuss ribbon cable connector to the right of the metal bar, up and away from its connection.
  9. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 9、 2の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 9、 2の画像 2
    • Use the tweezers to pick up the metal bar starting with one side and moving to the other.
    • Lift it straight up from the device.
  10. Samsung Galaxy View Sound and Power Buttons Replacement: 手順 10、 3の画像 1 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 10、 3の画像 2 Samsung Galaxy View Sound and Power Buttons Replacement: 手順 10、 3の画像 3
    • Use your fingers to gently push each button through the hole in the device.
    • Use the tweezers to pick up the loose buttons and remove them from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Amberley Powell
メンバー登録日: 10/06/16
762 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,712
