はじめに
Broken or shattered display screen? Go ahead and use this no fuss guide to replace it in no time.
必要な工具と部品
Place the phone face down. Ensure that the side with the display screen is not facing you.
Locate the back door and slide open.
Remove the battery.
Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
Place your tool under the labeled ribbon and pull gently to detach the ribbon cable from the motherboard.
At this point, the motherboard should be completely detached from the rest of the phone.
4 の人々がこのガイドを完成させました。
