メインコンテンツにスキップ
Samsung Galaxy Tab S3 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S3 Motherboard Replacement, Display: 手順 1、 1の画像 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 2、 1の画像 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 4、 3の画像 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Motherboard Replacement, Rear glass panel: 手順 5、 2の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement, Rear glass panel: 手順 5、 2の画像 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Motherboard Replacement, Battery: 手順 6、 2の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement, Battery: 手順 6、 2の画像 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 7、 1の画像 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 8、 3の画像 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 9、 2の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 9、 2の画像 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 10、 2の画像 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 11、 1の画像 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: 手順 12、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: 手順 12、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: 手順 12、 3の画像 3
    • Use the black nylon spudger to lift the gray ZIF connector up and pull out the orange ribbon cable below the camera.
  13. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 13、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 13、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 13、 3の画像 3
    • Remove the ribbon cable for the front facing camera after popping the red ZIF connector bar up with a spudger.
  14. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 14、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 14、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 14、 3の画像 3
    • Disconnect the three press fit connectors in the top section of the midframe by prying upwards with the spudger.
  15. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 15、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 15、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 15、 3の画像 3
    • Pull back the green tape on the upper section of the motherboard with your tweezers to reveal the ZIF connector below.
  16. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 16、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 16、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 16、 3の画像 3
    • Push the red bar up from the ZIF connector with the spudger and pull the orange, touchpad ribbon cable out.
  17. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 17、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 17、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 17、 3の画像 3
    • Use the spudger to disconnect five more press fit connectors on the left side of the motherboard by prying upwards.
  18. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 18、 3の画像 1 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 18、 3の画像 2 Samsung Galaxy Tab S3 Motherboard Replacement: 手順 18、 3の画像 3
    • Pop the coaxial antenna cables off from the motherboard with the spudger.
  19. Samsung Galaxy Tab S3 Motherboard Replacement: 手順 19、 1の画像 1
    • Using your fingers, move all the cables aside and wiggle the motherboard free.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sarah Westberg
メンバー登録日: 03/11/19
23,043 ポイント
70のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,732のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 3,574
