はじめに
The Samsung Galaxy Tab S3 motherboard replacement has multiple steps but once you have gone through the display and battery removal, the motherboard replacement is a straightforward process. Be warned that there are many connectors to undo. A malfunctioning can cause the device to not turn on, unusual visuals on the display, or if your device crashes regularly.
必要な工具と部品
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
この手順で使用する道具:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Use the black nylon spudger to lift the gray ZIF connector up and pull out the orange ribbon cable below the camera.
3 の人々がこのガイドを完成させました。
