はじめに
If your home button is sticking, or not working you may need to replace it.
必要な工具と部品
Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
Using the plastic opening device detach the rear connector of the home button from the device.
2 の人々がこのガイドを完成させました。
2 件のコメント
Nice writeup, but I can't seem to find where to buy the home button. Anyone know?
Mais, où acheter le bouton????
