メインコンテンツにスキップ
Samsung Galaxy Tab S2 Auxiliary Port Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S2 Auxiliary Port Replacement, Screen: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 4、 2の画像 2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Samsung Galaxy Tab S2 Auxiliary Port Replacement, Panel Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab S2 Auxiliary Port Replacement, Panel Replacement: 手順 5、 2の画像 2
    • Remove the nineteen 3mm Phillips #1 screws.
  6. Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 6、 2の画像 1 Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 6、 2の画像 2
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
  7. Samsung Galaxy Tab S2 Auxiliary Port Replacement, Auxiliary Port: 手順 7、 1の画像 1
    • Locate and remove the 3 mm Phillips #1 screw holding the auxiliary port in place.
  8. Samsung Galaxy Tab S2 Auxiliary Port Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to gently lift and remove the auxiliary port connector from the device.
    • Once this is done the headphone socket can be removed with your hands.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jovina Martinez
メンバー登録日: 01/20/16
2,099 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 10-4, Remmell Spring 2016 USF Tampa, Team 10-4, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S10G4
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 19
今までの合計 8,543
