はじめに
If your home button is no longer functioning properly, it may have become worn or gotten stuck over time, this guide can help you replace it.
必要な工具と部品
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
Remove the four black 3mm screws using a PH000 Phillips screwdriver.
もう少しです!
終わりに
