メインコンテンツにスキップ
Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Back Case: 手順 1、 1の画像 1
    • Turn off the tablet before disassembly.
    • Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
  2. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 2、 2の画像 2
    • The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
    • When prying open near the home and touch screen buttons, use a suction cup.
    • Do not stick the metal spudger past these buttons as this may damage your device.
  3. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 3、 2の画像 2
    • Carefully lift up the screen.
    • There is a ribbon cable attached. Lifting the screen too quickly can damage the cable.
  4. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 4、 3の画像 3
    • Remove the ribbon cable using the Metal Spudger.
    • The ribbon may be taped underneath to the grey frame. Gently lift the ribbon to untape it.
  5. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 5、 2の画像 2
    • Remove all seventeen 3 mm screws using a PH000 Phillips screwdriver.
  6. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 6、 3の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 6、 3の画像 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 6、 3の画像 3
    • Lift the black frame using the two Metal Spudgers shown.
    • On the third picture, there is a Sim Card component that is connected to the frame and back cover. As you lift up the frame, it'll detach. This is normal.
  7. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 7、 1の画像 1
    • Once lifted, flip the grey frame over.
    • This component connects to the sim card.
    • Remember to click this component back into place when reassembling the tablet.
  8. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: 手順 8、 3の画像 1 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: 手順 8、 3の画像 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: 手順 8、 3の画像 3
    • Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
    • Remove the four black 3mm screws using a PH000 Phillips screwdriver.
  9. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: 手順 9、 1の画像 1
    • Hold the frame and pop the battery off from the other side.
終わりに
作成者
5人の作成者と共同で作成されました。
Divya Prabakaran
メンバー登録日: 02/20/17
633 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S2-G4, Sullivan Spring 2017 USF Tampa, Team S2-G4, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S2G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 25
今までの合計 1,621
