メインコンテンツにスキップ
Samsung Galaxy Tab S2 8.0 Home Button Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S2 8.0 Home Button Replacement, Screen: 手順 1、 1の画像 1
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 3、 2の画像 2
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 4、 1の画像 1
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 5、 1の画像 1
    • The screen is now detached from the rest of the tablet.
  6. Samsung Galaxy Tab S2 8.0 Home Button Replacement, Home Button: 手順 6、 3の画像 1 Samsung Galaxy Tab S2 8.0 Home Button Replacement, Home Button: 手順 6、 3の画像 2 Samsung Galaxy Tab S2 8.0 Home Button Replacement, Home Button: 手順 6、 3の画像 3
    • Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
    • Lift up and remove the panel of the board using a plastic opening tool.
  7. Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab S2 8.0 Home Button Replacement: 手順 7、 3の画像 3
    • Use a plastic opener tool to remove blue connector underneath the home button.
    • Remove the home button by carefully lifting it and pulling the attached cables through the panel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jonathan Wood
メンバー登録日: 04/18/17
1,011 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S17-G1, Banghart Spring 2017 Cal Poly, Team S17-G1, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G1
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,615
