メインコンテンツにスキップ
Samsung Galaxy Tab S2 8.0 Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S2 8.0 Camera Replacement, Screen: 手順 1、 1の画像 1
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 3、 2の画像 2
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 4、 1の画像 1
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 5、 1の画像 1
    • The screen is now detached from the rest of the tablet.
  6. Samsung Galaxy Tab S2 8.0 Camera Replacement, Camera: 手順 6、 1の画像 1
    • Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
  7. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 7、 2の画像 1 Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 7、 2の画像 2
    • Use the plastic opening tool to lift and remove the plastic motherboard cover.
  8. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 8、 2の画像 2
    • Use the plastic opening tool to detach the camera's ribbon from the motherboard.
  9. Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 9、 2の画像 1 Samsung Galaxy Tab S2 8.0 Camera Replacement: 手順 9、 2の画像 2
    • Carefully remove the camera from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jonathan Wood
メンバー登録日: 04/18/17
1,011 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S17-G1, Banghart Spring 2017 Cal Poly, Team S17-G1, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G1
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 11
今までの合計 887
