メインコンテンツにスキップ
はじめに
If your battery does not charge consistently, or will not charge at all, your charging port may be faulty. If you are experiencing charging difficulties, the charging port may need to be replaced. This guide will show you how to do so.
  1. Place the plastic opening tool between the face of the display and  rim of the back cover of the device. Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Remove the back cover after the entire rim is disconnected.
    • Remove the back cover after the entire rim is disconnected.
  4. Remove the two 4 mm Phillips #000 screws securing the micro USB port. Remove the two 4 mm Phillips #000 screws securing the micro USB port.
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Using the plastic opening tool, disconnect the charge port from the motherboard. Once disconnected, lift to remove the charging port.
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
終わりに
31 の人々がこのガイドを完成させました。
Trent Chapman
メンバー登録日: 2015年10月01日
1,360 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S12G15
4 メンバー
12のガイドは作成済み
6 件のコメント
It is so amazing and it works!
alva chan - 返信
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - 返信
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - 返信
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - 返信
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 55
今までの合計 13,947
