はじめに
The back cover protects and covers all of the inner components of the Samsung tablet. In order to access any of these component, the back cover will need to be removed. Additionally, if the back cover has become damaged, this guide will show you how to remove and replace it.
必要な工具と部品
Place the plastic opening tool between the face of the display and rim of the back cover of the device.
Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
Remove the back cover after the entire rim is disconnected.
I did some diy fixing because my tab-s came having issues. All battery connection related. Easy fix about 10 minutes but now the back cover won't sit flush and there's a large gap…idk what to do now it's infuriating there no broken tabs or connections
12 の人々がこのガイドを完成させました。
3 件のコメント
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
Will a butter knife work?
Team Diamond (DrDiamond53) - 返信
You could try a credit card, avoid metal tools.
Isaac Pettis -
The battery is still connected at this stage so, yes, avoid metal tools.
Once the outer frame was mostly unclipped with the opening tool, I found the ifixit triangle plastic picks useful. As well as clips around the 4 edges there are maybe 4 more clips in the centre of the back cover that are a challenge.
Make sure the display screen and logic boards and battery all come out in one bundle, just leaving a bare plastic back shell. Others have reported that if you separate the screen from the boards you’ll invariably break a ribbon cable and lose touch sensitivity.
Michael Morjanoff - 返信
