メインコンテンツにスキップ
Samsung Galaxy Tab S 10.5 Headphone Jack Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 手順 1、 2の画像 1 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 手順 1、 2の画像 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 手順 4、 3の画像 1 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 手順 4、 3の画像 2 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 手順 4、 3の画像 3
    • Place the plastic opening tool in between the outer rim.
    • Move the tool in a downward motion to separate the 2 parts.
    • Run the tool along the rim to disconnect all connectors holding the outer rim to the back of the device.
  5. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 手順 5、 1の画像 1
    • Repeat this step for all four sides, then remove the rim.
  6. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Headphone Jack: 手順 6、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the two screws holding the headphone jack.
  7. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 手順 7、 1の画像 1
    • Place the hook of a spudger on the backside of headphone jack and pop the headphone jack out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ronald Dixon Flowers
メンバー登録日: 02/20/20
139 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 616
